water meth - pro's , cons ??
gauge ?
Does Cetane effect timing ?
i have : 05 2500 nv 6 speed , south bend clutch, tst box , 6" stacks
i'm triing to add a lil more power with safe EGT's .
with this set up i can only run level 2 - 2 on the tst without getting over 1400 - 1500 degrees
my goal is 800 lbs and 400 hp with 1400 degrees ... . is this possible with stock turbo??
what bad things happen when you run water through the motor???
dug
