Water Meth
Haisley's vs. Scheid's machine work
Leaky Westach FP sending unit
Not GPM's that's fur sure!!!
Lil bitty squirt from a boost signal hookup when under BOOST, depending if you get the controller or Hobbs switch... .
Having high E. G. T. issues?
Yup... . 370's and a 0 plate with only a Green filter and 14cm Exhaust housing... it's quite enough.
GPM... Well it may not be quite that much... but I know the BIG guys run quite a bit! I don't want to build a system that's only good for a little while. I'd like to make it a perminant system that will be good with Twins... etc. Haisleys Rock Hard Ram runs 5quarts in a run! I won't be THAT high. . but... . you get the idea...
Josh
Consider install a 15 gal tank in your box, I refill mine about every 3-5 tanks of fuel. I have found that 30% meth is about as high as you go before you lose cooling performance. snows variable system works well, gives you control.
Matt has a new controller that he's about to release that is a dash mount (small) and you can adjust it on the fly, it varies pump speed verses boost pressure and EGT so the the higher the EGT the faster the pump runs.
Jim
