Recently, I noticed some coolant on the garage floor... a teaspoon amount perhaps. I tracked it up to the water pump and could see it leaking at the block/pump interface. With 200K on the original pump I decided to replace the pump as well as the o-ring gasket. The original gasket was hardened pretty good.
The new pump and gasket went on without any problems and all the surfaces were very clean and true looking. However I noticed I once again have the leak from the same location. I don't drive it much. I'd say the gasket held for about 6 months and then the leak returned. Will sitting cause the gasket to "shrink" or do I need to silicon the edges of the oring before I install a new one again? Or silicon the metal pump mating surface around the outer edge?
