Water Pump weep hole
Radiator drain valve
Payload Problem
I've noticed that the 30K scheduled maintenance chart says to check the water pump weep hole. After looking around from the top, from underneath and the sides, I can't seem to find a weep hole on or near the water pump. Can someone clue me in on this? Thanks.
1999 Dodge Ram 3500 Quad Cab 5 spd; 4:10 LSD rear; Mag-Hytec diff. cover; Speedliner spray in bed-liner; Amsoil foam air filter; Smittybuilt step rails; JVC 12 disk CD system; Windows tinted; Manual transmission filter kit; Geno's EZ Drain oil pan plug; US Gear EGT and Boost gauges on a twin A pillar mount. Towing a 31 ft. NOMAD single slideout TT.
Rammin' and Runnin' the roads
It is on the bottom slightly to the pass. side, on the rear of shaft part of the housing. It is hard to see. Get a good light and a piece of wire to poke in the hole.
Paul A. Schmidt
95, 4X4, SLT 2500, 5 spd. , 4. 10, 270 hp. TST, Pacbrake, Walker muffler,
GearVendor O. D.
Eastern PA.
