I just got back less than 24 hours ago from a trip to Wisconsin, towing a big trailer. Our gross weight going was 22K, less on our way back which meant a few hills pulled in 2nd gear - specifically, the continental divide near Butte, MT, to name one.
While the weather was below 75 degrees, the water temps would climb a little above the "normal" range on the gauge. But on the way back, I hit 90's for the weather. Just running on the flat or slight grades, the gauge would swing past the upper end of "normal" pretty quick.
I'm sure I have a few bugs blocking things, but it's not bad. Further, I had the radiator out before I left, had it flushed, etc. I didn't lose any water, the burp tank didn't rise...
So just how hot is "hot" and is that normal at all? Those of you with 200+ hp at the wheels... . Can you pull extended grades in lower gears at WOT without seeming to overheat?
