Way lifted show truck on Ebay
780 Miles + 11,000LBS + 70MPH = 13.2MPG
Edge/what setting do you use for Gas Mileage
Too much lift... can't run a trackbar like that with full hydro, not to mention full hydro is not street legal.
$16k in a pile of tubing and rod ends? AS IF. I have about 2k into the suspension on my Jeep (4 linked, etc) and it's setup 100x better than that thing. (www.98jeepzj.com if your curious)
The one Bob posted looks to have Rockwell axles. A much better choice than the stock Dana axles. The dropped ball mount is a bit scary though!
Why do these keep coming up? I swear I have seen this one listed before.
BTW - the no front driveshaft is for a very different reason. Did you check out the t-case shifter location. Let's see, 49 inch tires, too cheap to re-gear, pull the front shaft and drive it in 4-low.
I am thinking with the 6 speed and CTD that gearing isnt a problem. Hell I can start off in 3rd gear with my dually if I am on fairly flat ground.
I just think it's kind of ironic how much conviction the seller has in the vehicle because the builder told him so.
I don't think it is street legal anywhere. I was under the impression that full-hydro steering wasn't legal on any street driven vehicle. If it was legal, it would be on everything because it's way less expensive and much easier to package.
This guy makes me nervous. I would sure like to see them put a driveshaft in it. With that pinion angle, I bet it would break as soon as it moved.
I would own two of them. One to crap on and the other to cover it up with.
Bob knows all the guyz w/ sweet rigs.
last time checked a truck was built for work. what a joke. worthless comes to mind. just trying to sell it off as art (which i dont appreciate or care for).
i should ask if he can pull the lift off :-laf
boy i tell you what that sure would make oil changes easy. of course with that much lift by the time it reaches the oil pan its going to have some good force behind it and i don't want to be there when it splatters everywhere.
Hydro steering or not, that thing won't be legal in most places due to the height of the bumper. Of course, when it tips over, at least one side of the bumper will be closer to the ground!
At least six reasons not to own it:
1. I couldn't wash it.
2. It probably isn't street legal.
3. It won't fit in my garage.
4. I think it is ugly.
5. Won't fit in ANY parking garage.
6. I already have a Dodge Ram CTD truck.
Mark H
