WD and/or Airbags?
terry little
Advice needed
Should they be used together or one or the other? If only one which one is better? Seems like bags may be easier to setup???
Although the "apparent" result is the same, they do different things. The WD bars, if they are setup correctly, will transfer weight from the rear to the front wheels and by doing so, level the TV *AND* add stability. The airbags only level the TV.
100 Proof
