More diagnosis is needed. The above covered some things.
These systems are known to snap doors broken. Check for airflow out of defroster or heater ducts.
Electrical: Check blower motor resistor for a crack, burned wires at resistor plug, and motor. Above covered ign switch bad and ign connector as full current goes through the switch. All 4 things can be bad at once. Quick and dirty is to measure battery voltage with blower on high and measure voltage at blower motor. IMO anything over 1 volt lower at the motor is trouble. Be careful as bad connections heat up the wires and connectors that can burn you. IMO I replace blower motor if any wiring or connectors are burned and I do so from the dealer. With a motor replacement I also do the resistor pack and note it's been updated for some years to not crack as much. I don't want a Red Communist knock-off that is noisier than the OEM motor.
