Weekend of Bombing!
Dr Performance Products
Amsoil By-pass system
Just spent the whole weekend adding a BD exhaust brake, 4" Jardine and Pyscotty! Thanks to all you good folks on the register, most everything went well. No problems with any of the components either. The 60lb exhaust springs did test my abilities. Neither of my spring compressors worked well, the springs would not compress straight and kept popping out of the tools. Is there a specialized spring compression tool for the 5. 9? Getting the keepers to release was a bugger too. After the springs were in, I ran the truck until hot then changed the oil/filter in case I missed some dirt, etc. Good time to install Gino's finger touch drain valve. All in all, I learned more about my engine/truck then since I bought it last October. I have my silencer ring so the sound level from the Pyscotty is barely noticable although that may be just my hearing. No problems fitting the Jardine exhaust up or leaks and the sound is a pleasent drone. Best of all is the BD. I used to love my Jake brakes when I drove diesel car. While the exhaust brake does not have the power of an engine brake, it still is worthy. One note on the BD installation, drilling the gas pedal would be easier with an angle drill. Next up, post turbo temp gauge, bigger injectors!
97'3500 SLT CC,4x4,5 spd,4. 10,83K,EBY aluminum flatbed,Dee Zee running boards,Dee Zee Platinum drop boxes,Mag-Hytec,BD Brake,Pyscotty,Jardine 4",TST plate,Bilstein,Isspro,KN,PIAA Superwhites,25' 14k beavertail gooseneck,Hale 2 horse BP
Hey, nice work!! Now for a set of Stage III A's and and PE #ad
2001 4X4 ETH 6 spd, QC, SLT,SB, 3:54, Flame Red,camel tan leather, 4" exhaust turbo back, EGT,boost guages, Stage III A's, Edge Products Module, Line-X bedliner.
License Plate "1QIK4X4"
Project that got way out of hand: total "BOMB"
95 Wrangler 4. 0L, NV4500, Reverse cut Dana 60 rear 44 front, Altas II, Quarter Eliptic suspension in rear, coils up front, Warn 10,000 lb to turn me right side up and the list goes on!
Hey, Mike,
Quarterhorse has a 96. He needs a TST plate and 370 hp marine injectors, not a power edge and honed injectors!!
Bombs away!
Joseph,
No, it's a 97 and I have a plate but am not totally sure which one. I bought the truck used and had the engine looked over, valves set, etc. As this was my first ride in a Cummins, the mech confirmed my feeling that it had a plate but I did not think to ask which one. I have not really looked into figuring it out either. I have thought about the injectors though. I think my next BOMB is going to have to be a Rambi Slayer. Part of my route home from work at midnight is kind of like running the gauntlet. The thought of the radiator, condensor and intercooler up there leading the way is scary! I appreciate the suggestions though.
