Let me start be saying that I do have formal training for climate control, but have no real field experience.
My questions:
Is the orifice tube in the tube between the dryer and the low side port where the line has a joint and is slightly larger in diameter?
If the tube is plugged, what would have caused it other than parts of my a/c compressor?
History:
Well, last year I noticed the clutch wasn't cycling for the defrost. When it got warmer, the A/C was dead. I took a job at a dealership with the proper equipment.
I pulled the system down and checked for leaks. The system only pulled 1. 3 of 1. 9 pounds out. (from what i'm finding on here, this is normal. ) Pulled a vaccum. It did just fine.
We charged it, the a/c worked for a few minutes and stopped. We recovered it again. Pulled another vaccum. Still no sign of a leak.
Recharged it with dye in the mix. Ran it again. Never found any dye, anywhere. Gave up thinking it was the evap core. Also checked it with a sniffer.
Now, last night, I decide to try again, since I wasn't satisfied that it was the evaporator core. Recover the system. It pulls out . 48lbs and pretty well stops. I let it sit a while on . 48
Our machine has a 15 minute vaccum setting. I let it run through the 15 minutes, shut the machine off and check the gauges perodically. It held vaccum for 45 minutes. . never tried to move the needles.
We charge the system, I program the machine for 1. 9 lbs (1 lb 14 oz) and let it rip. I walk away again. in 1/2 hour, it only charges 1 lb.
I start the truck, thinking it will pull a little into the system. the low side pegs the gauge (over 120psi) and high side is sitting constant at 150 psi.
I think the orifice tube is plugged. 80 degrees ambient temp.
My questions:
My questions:
History:
My questions:
