Weld F1 20" Wheels
I took the plunge for Bully Dog step III's!
4.5 Inch hole saw available
Did anyone else see the add for the Weld F1 forged aluminum wheels? They come in sizes up to 20" in diameter. Does anyone know if the bolt pattern will fit a Dodge 2500? I think they look much better than the Ricksons and should be lighter too. They look REAl nice. Also, there are several commercial truck tires in the 20" rim size. Thanks.
MichaelT
2000 Ram 2500 SLT, 2wd Regcab, Driftwood/Agate, 6spd, ETC Diesel. Rickson 19. 5s, Simulators, Michelin 225/70R19. 5 tires, Reunel double break rear bumper, van Aaken CPC, TST Competition PowerMax, RV injectors, HX40-16cm2, 5" exhaust
Mike
I'd but money on those comercial truck sizes having the wrong type of bead to mount on what is meant to be a rim for ZR or higher speed rated rubber, Ferrari and Mercedes AMG use that size on an OEM basis. Provided the bolt pattern was available, you could buy some of the aforementioned speed rubber, but it would kill your weight carrying ability and likely wouldn't last long, low profile side walls, heavy stiff riding vehicle, smells like wheel failure to me.
FIW
Good Luck
Max
