Cummins724
I welded my rearend gears & tried a test drive. The truck won't move now. What did I do wrong?
The problem is that you welded the wrong gears together. You should have welded the spider gears together, not the ring and pinion.
I got quite a big laugh and a fart from that one, Moe
If you look closer, You'll see that the pinion is not even in the housing but just sitting on a piece of metal on a table. NOBODY is that dumb!
