If I had to have one welder, for repair work it would be an ac/ dc stick machine. On a good machine, with adjustable arc voltage , it is possible to weld very thin metal with a low setting, and a small rod. To weld stainless, or alloy steel, just select the proper rod. You can weld aluminum also with decent results, if you are good. No matter what welder you buy mig or stick, buy one with infiitely adjustable amperage or voltage settings. The cheaper units are not infinitely adjustable, and just have click, or notch settings, every so many amps( stick), or volts( Mig). My personal choice would be a good stick/ tig machine, once a person has learned to Tig, they wont want to use the mig for thin material any more. A Mig is excellent for High speed fabrication of mild steel, but as far as a repair machine I think they are overated. For aluminum you'll also need a spool gun( aluminum wire needs to be pulled, and not pushed, and another tank with different gas). There are many people out there buzzing stuff together with Migs, that cant weld , thats why they like the Mig. They get a weld that appears good, but many times it not. Mig welding, is a good weld, but actually takes a good amount to practice to get good penetraion, and have a good weld.
