The 5p(6010), 5p+, and 6011 will work better with moisture because the flux coating is cellulose based. I would use 7018AC rod to do cover ups especially if what your welding will be put under any kind of real stress. Just make sure the 7018 is either new in package or put in your oven to warm up at 400* for at least 3 hr. before use. It'll weld a whole lot better if warm. Never ran the 7018AC rod but love the low-hy rod with DC+. If you could afford it, the Lincoln 225 AC/DC machines work real good and don't cost as much as a MIG or tig/stick machine like fab shops use. An added plus is that if you felt adventuresome, you can run tig with the 225 with a dry lead and argon bottle. Used them alot when working poultry plants and the tig/stick works just as good as the fancy tig machines, just can't do AC tig with them cause they don't have hi-frequency.
