For any of you who have found that the welds that hold the bottom of the bed to the sides are spiltting, there is a simple fix that will stabilize the crack. My '96 was developing a split between the bottom of the bed and the vertical pilliar on each side of the rear bed area. I didn't know it was splitting due to the bedliner that covered the area up. You can make 2 "L" brackets from flat stock steel with a small gusset welded in the corner of the bracket. Each of the piece of flat steel is approximately 7x7x2. The tail lights have to be removed to bolt the bracket in place on each side. Attach a ratchet strap at the bottom of each side of the bed and pull the bottom side rails back into place. Watch were you place your hooks on the strap, because sheet metal bends easily. Do not pull at the top of the bed rails or you will pull the top of the bed together and not the bottom. Once you have the bed pulled back into place, drill holes through the bottom piece of flat steel and through the bottom of the bed. Make sure your hole placement will allow you access to the bolt on the bottom side. I used 1/2" bolts with flat washers and lock washers to distribute the load on the thin sheet metal. The crack has not grown any more and the tailgate fits like it should. Make sure you check how the flat stock fits together in the corner before welding. We had to make some minor modifications on the angle due to the pillar not intersecting the bed at a 90 degree angle.
