A few years ago, I installed the WESTACH - 2" COMBO GAUGE - HIGH OUTPUT - BOOST/EGT from Geno's. On Saturday, the EGT side went dead, today on my way to work, it reads lower than it would normally read. I visually inspected the EGT sender, meaning it is still installed into the exhaust manifold. I did not remove the sender so I can't say what it looks like inside of there. I plan to open up the dash and see if there's a loose wire and to check the wiring to make sure there's no chaffing or shorting. Has anyone else had a similar experience with this guage?
