After a LOT of consideration I finally purchased and installed a Westach 0-16psi fuel pressure gauge in my virtually stock '01 3500. I used to occasionally check FP with a service gauge but I am concerned about an "in operation" incident that could result in low pressure.
Anyway, the gauge works great but...
I installed a Vulcan BIG LINE and pump relocaton kit last summer.
The pump was replaced when I got the truck June, 05.
Service gauge pressures with the original lines was around 12 psi on a 100 psi gauge so I was expecting similar with the current setup. Unfortunately I don't recall checking pressure after the Vulcan kit install. So much to do - so little time.
Pressures with the new Westach gauge runs 15+. It will drop a couple WOT getting up to speed on the highway.
I should have purchased the 0-30 psi gauge and the Vulcan kit was worth every penny to help supply a good amount of fuel to the VP44.
I am going to see if the gauge readout increases with higher resistance from the sender (or opposite) as I might add a small resistor in the circuit to move the needle down a bit. Funny thng is I read yet another FP gauge thread just after ordering that recommended a 30 psi gauge over the 16 even for stock apps.
