I just installed a Westach 0-30 gauge on my 2000 3/4 ton S/B.
Was installed with the fuel pressure line from Geno's garage.
The gauge has power (from fuse #16). The backlighting also
works. My problem is that it does not register any readings.
I installed the fuel line so that the end nipple inside would engage
the schrader valve on the test port.
The needle does swing to about 2 psi when the key is on or in the
accessory position.
(not forward enough to activate the lift pump)
what gives?
accessory position.
what gives?
