Details here: TDR Privileges
I have the Westach fuel Pressure Gauge, I used Geno's 18" hose to the V/P Schrader Valve. The problem, is the needle is pegged to the top, and stays there, at idle, cruise and WOT. It does not move.
I went through that BS with their micky mouse connecitons in the back and the joke of install insructions. Try reversing the power wires (Pos & Neg) at the sender Also make sure the light goes to the ground and direct power NOT power to the sender.
If I remember correctly, with the gauge right side up, and looking at the back;
The pin at 10 o'clock should be red to the sender
2 o'clock is direct to positive 12v power feed (key on)
5 o'clock is black to sender/ground
The light gets connected to the 2 o'clock and 5 o'clock
