Just a word of warning to those using the Westach fuel pressure gauges. On the way home last night, my post-filter fuel pressure started reading about 3-4 PSI lower than my pre-filter pressure - normally, they're within 1 PSI of each other. Since I hadn't fueled up in over a week, I didn't think I had plugged the filter with a bad load of fuel.
When I got home, I checked under the hood and immediately smelled diesel fuel. It turns out the post-filter sending unit was leaking diesel fuel around the electrical terminal screws that go through the case. It was so bad that I had a puddle under the truck. I tried tightening the brass knurled locknuts, but to no avail. I'm guessing that I have a ruptured diaphragm in the sender. Fortunately, I had a spare sending unit that was a warranty replacement, so I changed the senders out, and the failed one is heading back to Westach next week.
If you smell diesel, or if you start getting funny gauge readings, check out those senders!
Rusty
Rusty
