I have replaced the sending unit on my Westec fuel pressure gauge three times in the last year. They all start leaking at the seam where the top and bottom halves of the unit join. I use a grease gun hose tapped in with a tapped banjo bolt at the fuel line inlet at the injection pump. The hose runs up to the airhorn and is mounted simi-ridgidly. It is a 16 psi unit and is reading 15 psi at idle and 10 WOT. Is there some problem with my installation? I'm at a loss and would like to come to some conclusion before ordering a new sender or different brand gauge. Any thoughts would be appreciated. Thanks.
Jonny
Jonny
