Hi all,
I was under the carpet installing wiring for emergency strobes and discovered that my carpet mat is soaked and I mean drenched with water like a kitchen sponge on both sides of transmission and both front and back of truck.
The carpet itself is totally dry but under the rubber base of the carpet where you find the thick carpet mat, it is soaked. I would have no idea of the water being there (and rust bubbles) if I had not lifted the carpet up.
Clearly the water is trapped between the carpet's rubber base and the metal floor.
So,
QUESTIONS: (yes I did search the archives):
What is the best way to dry out the mat? (I think I have to pull the seats and carpet, etc... .
What are the places which are the best suspects for this kind of water problem? again, no sign of water on the carpet itself
I see small rust bubbles forming on the floor from the water being trapped against the metal for probably a very long time, what should I do about that? 65Kmiles...
I wish I could find a product to help wick the moisture out of the floor.
I guess I will probably pull the entire carpet and mat and just put the front seats back in until it rains next to see if I can locate the source of the problem. Any suggestions would be appreciated!
Thanks all,
David
PS: there is a small hole in the carpet under the drivers seat where the wiring comes up for the seatbelt harness. Stick your fingers down all the way to the metal floor there to see if your mat is soaked like mine is!!
So,
Thanks all,
David
