what 205 will fit ??
Pods Vs. Power Wagon Injectors
Headlight Switch
newbe ??? I"m looking for a 205 xcase to bolt up to a nv4500 for my 92 ctd which one will work ?? will one from a np 435 transmission work ?? is a np435 a dodge transmission ? you guys got any 4 sale ? thanks mike
My brother is just in the final stages of having his NV4500 conversion done at PDR, they are bolting the stock NP205 T-Case on with no problems...
Bob.
From conversation with Dan at Quad 4x4... .
You need a 205 that came from a stick truck. The one from the auto has a smaller input shaft. If you are not afraid of some machining, the auto would need to be cut to receive the larger bearing and seal, then larger input shaft.
Good Luck,
Pat
