What a breeze, THANKS GUY'S
Looking For Best Cell Phone Plan
Cobra 75 WX ST CB Radio
For all the information needed to make my FIRST ( 1130 miles)oil change a breeze. I did what a lot of you all did. First i took the beast out to warm up the oil. Came back, crawled under her and loosened the drain plug with a 3/8 ratchet and a 2" exstention to where i could get my fingers up there to unscrew the plug to where the oil started to drain( not to take the plug out all the way) into a 5 gal. bucket. Got my new strap wrench , put it around the top of the filter and grunted until it broke loose,than put a 1 gal. ziplock baggie around the filter,than spun it off by hand,& it's hot, so be careful. I than filled up my new filter,Fleetguard LF3894,up with oil than reinstalled, by than my oil was drained,so i than put the drain plug back in. I than put 10 qt. of oil back in the motor,started & idled ,rechecked ,right on. I decided,well, i my as well grease the thing,i only found 3 fittings, one on each ball joint,and another on ,i think it's called a stabilizer bar ? Anyway ,thinking there should be more i went to the dealership and talked to the guy (Lou)who works the lub rack,he said thats all there is,we got talkin and he mentioned something about REPLACING DRAIN PLUG WASHER EACH TIME,guess what,I DID'NT,I will next time ,i bought 1 while i was there $4. 50 ea. Sorry for being so long ,i just like sharing. OH,buy the way,what ever oil comes with the truck,it was dirty. Thanks everybody
2001 ETH/DEE - 2500
REG Cab 4x4
Patriot Blue/Driftwood, Rhino Liner
CAM,
Check out GENO'S finger touch drain valve. Makes the oil change even easier.
PS, I don't know about the 24v but my 97 manual says to let the oil drain for several hours so the oil drains from the injection pump. Being a second shifter', I come home, open the valve, get back to it in the morning.
Cam, glad you "graduated" #ad
Is that big ol oil pan plug scary or what? All the the people in my head where screaming DON'T! when I thought about dropping the plug all the way out. The thought of a Niagra Falls of hot oil made me think twice. I'll bet all 10 quarts would make it in the pan in 10 seconds #ad
Not fun if your using one of those oil containers with the tensy little drain hole...
2001 HO 6 speed Regular Cab SLT 4x4 3. 54 anti spin 2500. Used for the daily grind and sneaking away to some secret Baja beaches toting a cabover
Cam,
Check out this website www.fumotovalve.com you will never have to remove you drain plug again and will also keep your fingers clean.
WHITE OBSESSION" 99 Quad Cab, White, SLT, 4x4, 5-sp, 3:54's LSD, Raven cap (cab high), Rhino liner, Stainless Nerf Bars, Stainless Rocker Panels, Tow package, Pro-flap mud flaps with Stainless Cummins "C" add to rear flaps, Valentine One, Uniden PC78LTW CB, Hadley Bully Air Horns, Power Edge, Psychotty Air Induction, Braided SS Fuel Lines, 4" Jardine Exhaust (Love the deep throaty sound), 285/75R16 Cooper A/T's.
My 99 Dodge Cummins
Things to come;
Pyro, Boost and Fuel Pressure gauges, PE timing module and injectors.
NRA Life Member! (Need to protect our rights and FREEDOM!!)
[This message has been edited by BIG BOB (edited 10-15-2000). ]
QRTRHRS, us owners of "advanced" engines don't have to let our oil drain long because our "advanced" injection pumps are lubricated by fuel only. Aren't you jealous???
'01 Eth 3500 dually, no mods planned except maybe an amsoil filter & guages. See My Truck and also be sure to read What tools & methods to use for an easy 1st oil change!!!
"Be happy you don't get all the government you pay for. " -W. C. Fields
fast drainage is cool, but ya gotta love having about 50lb of precision mechanism devoted strictly to fuel metering and delivery!
P7100--- when you care enough to pump the very best.
another post says about 10 seconds to "dry" with plug all the way out... closer to 13 #ad
BOMBed 98. 4 1B7KF23D4WJxxxxxx-- BD's #5 plate and x-honed injectors--BD Brake and the associated transmission bomb goodies (except for TC,currently). . many homemade non-power accessories, 4" open exhaust(short)... big hole and old Scotty Air system(will eventually get Psychotty cannon, I suspect) camper shell, Warn front receiver, G159Unisteels on Rickson 19. 5's. . CD player is bone stock, so are the seats. PrimeLoc, also remote spin-on filter for the auto trans... Pyro Boost and Trans temp from Isspro,
Westin nerf rails(black),
bent welding rod to hang celphone on dashboard...
The only reason the dealer advises that you replace the washer at every oil change is so they can charge you $4. 50 at every oil change. Let see, mmm, how many oil changes a day do they do? Multiply that by $4. 50, multiply that my days in month. Adds quite a bit to the bottom line with no expence at all. Remember, every dealer out there, good and bad, are there for one reason, to make money. "It's Always About The Money"
You only real need to change the washer if is damaged or leaks.
My . 02
dmurdock,
Envious maybe, not jealous. I like the smell of new paint as well as everyone else. Had my share too! Now that I am older and just a hair wiser, I prefer to buy used. Plus, no hesitation on putting that big ol' 4. 5" diameter hole in for Pyschotty.
Now if that 24v was in a four door... .
I change the oil twice a year on my 92 (9 yrs x 2 x $4. 50 = $81) and never have replaced that washer - no leaks. But you sure have to be fast or else that hot oil will run right down you armpit - practise makes perfect.
Hey Guys --- Leave that oily,messy,dirty ole drain plug alone !!! Put on a Amsoil Dual Bypass filter system, fill it with 3000 series 5-30 oil, chg. full flow at 12. 5k, take oil analysis at 19. 5k, change both filters at 20k and go for it. #ad
CPFF
CUMMINS POWERED FAST FORD
I am a little more laid back. While the oil is hot I insert the tube from Geno's (will get the new one for th 2001) and start the oil to drain, lift the hood just enough so the light doesn't come on, to remind me the engine has no oil. I come back next morning and the oil filter is cool and not full which makes it simple to remove without spilling oil .
To each their own way. The easy way is have someone else do it but you must trust them they to do it right or you will be paying down the line.
