mattymac said:Thats nice HOSS! I wish that the pic showed the front tires better, I think that you may have pulled the front just a little on that run!
ob1kobi said:Sweet picturesWhat kind of 60 ft times are you guys pulling?
Ted
HoleshotHolset said:What kind of RPM/boost are you leaving the line with?
This is where a higher stall converter might help with the launch... but you'd be blowing through it going down the track. Darn tradeoffs...
Matt
Matt
HoleshotHolset said:How many converters have you fried from having the somewhat 'loose' fluid coupling and locking it up in 2nd? Seriously... No flames intended.
Matt
HoleshotHolset said:I'm glad you've had good luck with it. Loose fluid coupling and high HP/torque usually spells disaster for torque converter clutches... sounds like you've found one that holds up. Good for you, man.
Keep getting them short times and ET's lower... it's awesome to see the numbers dropping!
Matt
