I didn’t get so lucky on this truck my feed in pump tank keeps causing my external lift pump to suck air .
The in tank pump is dead . What can I do to bypass it . I don’t want an in tank pump Is the stupidest design anyone ever thought of. I guess unless your a dealer or shop why have a pump you can change in 15 minutes when you can have one you need to drop the fuel tank to change ? So is a draw straw a good way to bypass the pump in the tank and how do they work ?
Never had that much trouble with the engine mount pump . And that’s not the question I asked in the first place . Looks like I can get a draw straw or a fuel module without a pump in it . Not sure how a draw straw installs but it looks the cheapest. Out of 9 of these trucks I’ve owned I’ve replaced two engine mount pumps both trucks that have in tank pumps both died but oh I guess they are reliable .lol, if the in-tank pump was so bad why have then been used for a LOT longer than the engine mounted pump with a MUCH greater life expectancy and improved performance...
Do what you want, but spending any money on an engine mounted pump is futile. The reasons they are obsolete and a poor design are plentiful. You already have the wiring for the in-tank pump, do the smart thing and replace it.
In order to bypass the in-tank pump you'll need a new basket, if you can find one, for your tank that was designed for the engine mounted pump. I wouldn't run a draw straw, they have suction issues, even the newer ones.
