Boost, rail pressure, and EGTs?? I searched, however most readings were with a box/chip/module/tuner modifying things. I'm happy to say my Granatelli monitor is actually working fine now since I used the "other" dodge setting...
I'm seeing boost pressures of around 10 psi cruise, 36-37 psi max WOT... I think I remember this being "normal"??
I'm seeing rail pressures of 6k psi idle, 15-17k psi cruise, 23-24k psi max WOT... again, I think this is normal??
I haven't got the EGT gauge hooked up yet, but thinking ahead, what should I consider "max" EGT?? I'm seeing 1450 as "ok" for a 04. 5+???
steved
steved
