What are the side effects of lower stall speed?
Squeaky Quad Door
Cummins ROADRELAY 4
Recently I changed my TC to a low stall and added the TFOD shift kit. Maybe its my imagination, but it seems that my EGT's have gone up a lot. Also I seem to have much less low end response.
Has anyone else noticed this? Is this result expected, or am I seeing signs of a possible problem? Can someone explain what exactly lower stall speed is? What happens at the stall speed?
97 4X4 QC LB 3. 54 Auto w/ Suncoast TC, TFOD shift kit, Jardine 4 inch exhaust, TST #8 plate, Firestone Air bags Rancho 9000's
I haven't noticed any change in my EGT's ... but the LS is much tighter at the low end, once I get moving a few yards it really takes off.
The stall speed is the point where the convertor becomes a fluid coupling. If I am correct the stock stall speed is around 21-2200 rpm ... so . . much more slipping in the convertor. The lower stall speed applies the power to the rear wheels in the rpm range your Cummins is producing it's best torque around 16-1700 rpm.
After I installed mine and 600 or so miles later . . I noticed #1 and #3 exhaust manifold gaskets had sprung some leaks ... . probably just a coincidence . . but something to keep an eye on ...
'95 2500 Stretch 4X4, Auto, 265/75/16, white. TST #5 250/635 plate, 215/230 injectors, K&N, Cummins chrome, BD Valve Body, Pro-torque LS convertor, mystery switch, JRE 4" turbo to tailpipe w/ monster tip, ISSPRO boost and pyro, Pioneer CD system, Galaxy 99 CB w/ 400 linear, nerf bars, Rancho 9000's, 8K tag-a-long RV ... Life is Good!!
[This message has been edited by Rammin On (edited 06-30-2000). ]
