I have a 2000 3500 with 100,300 miles. It doesn't want to start when it is warm, but all you have to do is walk away, come back in an hour, and it will start right up. It also runs and starts normal, if it starts. It doesn’t seem to be an air issue.
For the people that have had VP44's go bad, what were your symptoms??? Did it just go out all at once? Did it run bad?? Do the pumps either work or don't work with no in-between? I am hoping that it isn't the VP44, but I have a truck, with 14psi of fuel at VP44, that sometimes starts and sometimes doesn't. It only seems to fail when the engine is hot and the outside temp is hot.
I have tried all electrical connections.
Can someone share his or her experiences with a bad VP44???
