2nd Gen Non-Engine/Transmission What are you guys reading?
Engine/Transmission (1994 - 1998) NW KDP Kit
Engine/Transmission (1994 - 1998) TC lock up smart boxes???
ON the highway @ say 70-75 mph level ground without a headwind or other limiting factor, what do you read?
EGT's
Boost
Fuel Pressure
Of course everyone will be different with mods, gears, tire size etc... .....
I live in the same state at about the same elevation as you Loganhill. Here are my readings...
EGT = 700 maybe a little less
Boost = 8-9 psi
Fuel Pressure = 12. 5 psi
I have stock fueling except for a Wildcat Max Flow Kit, and stock air system.
Jeff
At 70 mph cruising, same at 75crusing
opsi boost( unless going up hill or with load)
550-600 egt pre turbo
16psi fuel psi (FASS)
5k feet
700 - 900 Pre Turbo EGT
2 - 6 psi boost
13. 5 psi fuel pressure
AFE intake, no muffler, stage 2 injectors, relocated LP to the frame and no banjo bolts.
~5700 elevation
800 Pre-turbo EGT
3-5 psi Boost
9-10 psi Fuel (ya, it's a tad lower than I want)
Only have AFE Pro-Guard 7 drop-in for performance BOMBs.
