Our family is going to start RVing with a 5th wheel toyhauler (37-40') and are moving from a '99 2500 LB to looking for an '06/'07 3500 DRW 4X4 Mega Cab (stretched to LB) with a 5. 9/48RE.
I considered the 6. 7/68RFE (for the gear splits of the 6 speed), but decided to stay with the 5. 9 and are considering a Gear Vendors to split gears on the 48RE (manual trans not an option for us).
I'd like to hear from some of you concerning towing speeds/rpms and rear axle ratios. I have an Excell spreadsheet showing ratios/mph/rpms.
What speed do you tow at? What rpms do you find work well (at 55-65 mph) for controlling EGTs with a big toyhauler?
We've found a MC LB with a 3. 73. At 55 mph in 3rd, the rpms are 2150, in overdrive they are 1500 (below torque peak). With a 4. 10 at 55, they are 2400/3rd, 1650/4th.
Without the Gear Vendors, I agree the 4. 10 is better for towing, but not as economical unloaded (where it will see a lot of use).
What is your opinion though with the Gear Vendors? A 3. 73 in 3rd over would be 1700@55 whereas the 4. 10 would be 1850@55mph. Would a 3. 73 be workable with a Gear Vendors and big toyhauler? I'm concerned with egts, level towing power, and gear hunting by the 48RE. Thanks for your experienced opinions!
