Details here: TDR Privileges
just went through this with my Dads Motorhome. He did not have a deep enough area for the 6Volt'ers, so we went with the 29 series Walmart Everstart. Its cheep enough, has a good warrantee and can be replaced at far more locations then just about any other battery seller.
With the 29 series, he should be able to get at least 2 nights out of it with mild heat requirements
I agree. I built a battery box in my trailer to accomodate 4 six volt golf cart batteries. We do a lot of dry camping in the summer; running lights, TV and satellite, as well as two fantastic fans which run continuously and still have some power left after four days. Bought them at Sam's for around $50. 00 each. Got the plans for an acid proof ventilated battery box out of a marine maintenance book. Works like a charm and is a darn sight better than what the manufacturer put in the trailer.
I have a trevel trailer with two g27 batt. wish i could go with two 6 volts but i cant. You probably have room for one group 27 , 12volt battery in your camper. I would recommend Interstate. That is my opinion. Happy camping!! Jim
First of all, I wish I had a Bigfoot rig! I just recently "discovered" that brand. That is one really nice, well built unit.
You may want to look into the new Gel (?) type battery. I believe Sams has just started carrying them. Similar to the Optima mentioned below. A little pricey however.
Also look at this site: http://www.optimabatteries.com/ (see the Marine series) I remember a similar discussion on batteries a longtime ago on TDR and someone really really liked this series.
They indicated they have had warranty problems with the optima.
I also found out that the new style batterys probably aren't "gel cells", but are "Absorbed Glass Mat (AGM) batteries " They do have some really high amp hour rates, don't gass, don't spill, etc. Much safer, can mount anywhere (even sideways), apparently without any need for a box or vent!!
