what can i stack with my EZ?
05, is it driveline or exhaust induced?
Anybody know the part number?
this november i'm going to do a little more upgrading(new turbo and pac brake). my 600 gets a little hot towing my boat and has trouble stopping wit only 1 set of brakes on it. anyway, i have nice power with the ez and edm injectors but would like a little more. (yes, i have guages) i'm thinking a timing box or the BD downloader. once i put a bigger turbo on i'll need the extra fuel to get her moving. what do you guys think? thanks... . james :D
I would bit the bullet and get a Juice or TST powermaxCR
You could do a VA3. 2 - but that does not have timing...
no tst for me. i'm buying a house soon and cant afford to rebuild my transmission. i'm just looking for somthing to compliment the EZ. i can get the juice fairly cheap. is it stackable with the ez? i thought i had reas it wasn't... . james :D
transmission will hold up if you run the lower levels, still be stronger than the juice, and room to grow already in it.
tobaccogrower said:
no tst for me. i'm buying a house soon and cant afford to rebuild my transmission. i'm just looking for somthing to compliment the EZ. i can get the juice fairly cheap. is it stackable with the ez? i thought i had read it wasn't... . james :D
On 03-04 - no
on 04. 5-05 - yep!
(at least thats what I understand)
The EZ is definitely stackable with the Juice on 04. 5 600. Just added the EZ today. No problems, issues or codes.
JVOLPE-
had mine stacked on top of each other that way but found the juice gets pretty hot so I stacked them next to each other instead to try and keep juice box cooler. you might want to do this yourself. there is room on the fuse box box for each if you arrange them. Just a thought to consider. Have had juice stacked with ez for awhile now I like it.
Hokey
I know the Juice gets very hot sometimes, did you have any problems or just decide to move. I was going to sit side-by-side, but the picture looked better this way. I will probably move it tomorrow before I go to the track.
JVolpe said:
Hokey
They do look good that way. I didn't have any problems, just noticed how hot it got and was concerned so I moved them and also changed the velcro strips to try and get some air circulation going underneath. I only had them on top of each other for a very short time. maybe if a guy stacked them with an air gap between them somehow it would be just as good. let me know if you come up with any slick ideas.
It is common knowledge that the 48RE transmission is a major limitation when the owner decides to BOMB. I for one, opted for the NV5600, although I do live in Los Angeles with all the traffic jams... I know the NV5600 with an aftermarket clutch can take alot of more abuse.
Back to point, TST PMCR/EZ stacked is a nice option.
