Here's the text of a message I sent directly to Edge - but while they make great products, they are LOUSY at responding to email! So, I wonder if any here have some pretty well founded info to offer on my letter posted below?
I have had your Comp on my '02 2500 Dodge HO for several years with EXCELLENT performance, especially when towing our 5th wheel RV in the mountains.
I recently added larger injectors (Don M 1. 6's), and a BHAF and full Rip Rook 4 inch exhaust system.
I find that now I rarely need the Comp on at all for most situations, expecially in regards to added fueling - but it IS nice to have there for those rare "extra" need situations. I feel that the TIMING change provided by the Comp might sometimes be useful, IF the additional fueling could be prevented along with it. As I undestand it, the Comp DEfuels in the lower ranges 1-3 when the sub menu is set below 3, such as 1x1. How is this accomplished, is only the ADDED Comp fueling reduced or eliminated - or is the TOTAL injection pump flow reduced? I *do* see lots less smoke with the Comp on 1x1 than I do with it switched completely off with my added injectors.
Is it possible to connect the Comp normally, and still have it function essentially like your EZ, as long as only the lower settings are used, or must I disconnect the pump wire for that to happen? I'd really like to keep it connected normally to have full power available at the touch of a button, but might consider disconnecting the pump wire if that is the only way this can happen.
Thanks for your help
