what do all those abreviations stand for...?
Filter placement
WHAT IS THE BEST WAY TO LIFT THE FRONT END?
I'm new to the board and I keep seeing ETH and DDII's and EZ and PE etc: etc: etc: can somebody PLEASE fill me in?
2001 Red quadcab 4X4 2500 H. O. 6sp.
Hey I am fairly new also, however DD stands for Diesel Dynamics, at least that is what I believe and the II is the stage injector. 1's are the weekest, then II's are a little stronger then III's are the big boys. Hope this helps.
ETH is the DC order code for the H. O. engine. Your transmission order code is DEE. DD's are Diesel Dynamics injecters, Stage I, II or III. EZ's and PE's are plug in boxes that alter the output from factory ECM to the injection pump to improve performance.
Do a search on some of the early 24 valve posts, lots of good info there.
ex Ford tech, now driving '01. 5 2500 4X4 QC LB ETH/DEE SLT 3. 54, Patriot Blue
Taking it one step further:
PE=Performance Edge Fuel computer module.
275's= RV injectors (more powerful than stock)
DDI's=Diesel Dynamics Stage 1 injectors. Slightly more than the 275's, plus they are flow matched.
DDII's=Higher # means more Fuel/HP/Torque/Smiles.
DDIII's= more of everything above.
BOMB'd=Better off modified. . baby!!
A few others you may or may not know:
FWIW=For what its worth
BTW=by the way
OMO=Only my opinion
IMO=In my opinion
IMHO= in my honest opinion
BIL=Brother in law
etc... ...
I use OE or OEM alot in my posts.
Original Equipment Manufacture
[This message has been edited by HEMI®Dart (edited 02-11-2001). ]
Others not referenced FWIW. Use the above decoder cheat sheet #ad
ISB = Interact System B. This is your engine type per Cummins
24v = 24 valves in your engine. Which BTW are the PROPER number of valves to have in an ISB #ad
Michael
00 Driftwood 2500 ST QC ISB LB 5spd 3:54 LSD Tow & Camper Groups . . SunnyBrook 33FKS Travel Trailer
my photos
Michael,
24v may be the PROPER number of valves, but I think the IDEAL number of valves is 12! #ad
1996 Dodge 2500 4X4 SC, SLT, Cummins 12V, 5-spd. , JRE 4" exhaust (my kitty ran away into the woods and the muffler fell off!), TST 280 HP/685 Ft-Lb Uprate Kit, AFC Spring Kit, Horton Fan Clutch, Jacobs/Ram Exhaust Brake, MagHytec Differential Cover, Prime-Loc, Rancho RS9000 Shocks, Combo Gauge, K&N Air Filter, Brite-Box, Geno's finger-touch oil pan drain plug, Optima Yellow Tops, no turbo silencer ring, full-time fog lights.
