What do these codes mean?
Mud flaps
2WD lift spacer on 4WD?
23 91
27 01
29 00
a3 44
i did the dash light test and these came up. I was very suprised to see this many codes... Anyone know what any of them are?
Nick
This threw me for a loop at first, then I realized that you were doing the Instrument Cluster Actuator Test, and not looking for DTC's.
The first set of numbers/letters is the actual DTC for the inst cluster, the second set of numbers is the number of times the key has been turned since the code was set.
So here are the answers to your codes:
06 - MIL indicator output circuit open - 44 key cycles
23 - Headlamp switch input circuit open - 91 key cycles
27 - Courtesy/Dome output circuit shorted or open - 1 key cycle
29 - Cargo Lamp output circuit shorted or open - no key cycles
a3 - Battery voltage open - 44 key cycles
Knowing that you JUST had the dealer put your cab lights on a week or so ago, I would SPECULATE that they MIGHT have honked something up. I would definately get it checked out.
Hope that helps,
Andy
*EDIT* I see you jumped a few ponies since the last time I looked... What did you add to get to almost 100 extra HP? Did you add a box?
Andyman thank you very much. I appreciate it.
Now can these be translated to me in terms that when i call up my dealer i can tell them what is wrong?
As for the extra ponies. That isnt in effect yet. But yes i did order a Edge ez and i have my 4" exhaust and Scotty 3 coming.
Nick
I'm not sure I can help you there man. If I had to guess, I would say that maybe it has something to do with where they tapped power for your clearance lamps?? I meant to check mine last night and see if it had those codes. I'll do it tonight if I have time.
Re: the edge ez, I think you'll really like it. I had one on mine for a short while. It really woke the truck up.
see ya,
/Andy
