Engine/Transmission (1998.5 - 2002) What does the code P-1693 mean?
This is what I found.
P1693 (M) DTC Detected in PCM/ECM or DTC
Detected in ECM
A 9Companion DTC9 was set in both the ECM and PCM.
What does this mean and what causes it?
P1693 is only a generic code alerting you there is a more specific fault code deeper in the ECM or PCM that requires a more sophisticated code reader to view and correct. Some AutoZone and similar automotive stores provide customers a free check of the system with a code reader to help find codes and suggest repairs.
