Just went threw this ,,,,
For 1 thing the hy Charger With the waste gate 100% closed and a Tapped Comp I was getting 50# of boost ... . Efficiency range of the HX is the same for the HY which is around 23# so I had 25# of nothing but drive Pressure ,Nothing but HURT!
IMHO running an HY non Wastegated on any thing is BAD its a little instaspool
Here is a side by side pick of an hy and an hx
The hx35 is a major PERFORMANCE GAin for the HY equipt truck .
So far on my truck ive had
hy35 which is a 9 CM Ext Housing (35 # normal drivng)
Bombed Non waste gated hx35 with a 21CM ext Housing To much lag even with the Comp Tapped 5x5 and a full blown Catcher (35 # WOT UPHILL 5x5 Catcher About 100MPH)
Now resides a HX35 12 Cm and my truck is just like I want it ..... not much lag and around 35 psi WOT 5x5 upgrade It is waste gated (35# when you want it)
Ditch the Hy and pick up an HX I can get a used HX35 for $150 but you will have to wait in line .
if your willing to try the HX35 21 Cm Contact me and we can work something out
The 21Cm ext housing has been modded to fit on our trucks The Bolt Style instead of the clamp style .
Here is some info Ive gathered resently and I threw together a Install guide so you can see just how easy it is to Swap Chargers.
http://www.3d.otisnet.net/charger_swap.htm
http://www.3d.otisnet.net/turbo_101.htm
https://www.turbodieselregister.com/forums/showthread.php?t=132219
Good Luck
DM
