Details here: TDR Privileges
"I also assume you already have gauges, including a fuel pressure. "
With the comp on 5X5 I am seeing 18-12 fuel psi when I am driving w/stock injectors and stock turbo. Have not decided what type of fuel system upgrade I will get.
Yes a long time ago I'm at 428. 1 H. P. with 1K of torque. I have drag comp, DDII's,PDR HX35,4" EX, Scotty II, 7LBS 100 GPH pusher pump, 3/8th A-N fittings from tank to injection pump,Southbend OFE,Fastcoolers, Magek diff cover and lots more I can't remember. Generally I run 20PSI fuel pressure but at 5X5 I can pullit down to about 15 LBS. To say the least it's screams,but lots of fun andlots of
