Engine/Transmission (1994 - 1998) What injectors and Delivery Valves do I have?
2nd Gen Non-Engine/Transmission Bad Nitrogen can?
Engine/Transmission (1994 - 1998) MESSAGE for KDP procrastination
stock truck? DV's say have the # on the little valve. youll have to pull the injector out and match the #'s off that. what year and trans. if its stock i can tell you.
I changed the title of this thread (from "?") so you might get more help. Also telling what truck you have (create a signiture in user profiles) would also help.
Good luck,
Pete
Sorry, some more info. would have been helpful. The truck is a '98 12v w/ 5spd transmission. It's not stock. When we got the truck the previous owner said that the injectors were from Dr. Performance, and there had been some pump work done. I am currently looking into buying Lenny's stage 4 inj. and getting some pump work done at a shop in Knoxville. I'd rather not use the injs. that I have for a core if I can sell them and maybe make a little money off the deal. I also may be able to sell the DV's. That's why I asked if there was a way to ID DV and inj.
Thanks
Ryan
Oh yeah does anyone know how to create a signature so people know what I have, it has me totally stumped.
A stock '96-'98 5 speed will have 181 delivery valves and 215 injectors. Look at the USER CONTROL PANEL to set up a sig.
My recommendation on pump work: pull it and send it to one of the shops that are regarded well on here. I've done it both ways and you'll get much better results with someone tuning the pump that's already done a couple hundred instead of a local shop that hasn't.
