What is a #4 or #0 plate?
Engine Shutdown Timer & High Idler
Anybody put Sport taillights on there regular Ram?
I want to get more HP from my truck and was going to get a #5 plate to go with the 370 injectors I have on order from Piers. But I see a lot of signatures with a #4 or #0 plate what are they and what can be expected from their use?:D
Piers will ask you what kinda power do you want at the end, 370 will fuel like heck with any plate but fueling is ridiculous with a #4 and worse with a #0 as they are both off the charts. Read my sig, mine will make 1500 degrees by the 2-3 shift, that's 0-60 MPH and my plate is say . 050 back from the middle of the slot..... does that tell you anything of the capability:D
Jim
I'd stick with your current #8 plate and just put in the 370's for now. I'm running the number 6 full forward and am at my fueling limit until I do something serious in the turbo area :( You won't believe how much more fueling the 370's will give you when added to your current set up.
dan
I called Mark @ TST & asked him about the #4. He said it was designed for the auto pumps with gov spring kits.
Well ... figured it ought to work just fine in a 215 pump with gov springs. Boy did it! Can't do it with the HX35 in the 215 pump though. One thing about it though, you can slide it around & find it's egt sweet spot. :) And it's bunches cheaper than injectors. :)
you think fueling is rediculous with a #4 or #0
try a throttle lever stop ONLY plate :D
off the charts HUH, I burned them for heat waiting for you to catch up :D
