I just ordered a new one from Piers diesel. In the mean time, I removed the oem one and cleaned it out. As was already said, on the front of the injection pump, close to the engine is the fuel return line. That line is held to the pump by a banjo bolt with a smaller bolt on top of it. Remove the larger bolt, and go to the vise on your work bench. Without too much pressure clamp the larger bolt in the wise and unscrew the smaller one. There is a spring several small shims and a check ball. Mine had some junk in it so I cleaned it with carb/brake spray. Before putting it back together I used some extremely fine wet/dry sand paper to smooth out the cooper sealing washer on top of the large bolt. Be careful to get those small washers (shims) all back in. I put the shims on the small bolt, followed by the spring and then set the check ball on top. The I lowered the larger bolt down on to the smaller bolt. Basicly upside down so that nothing got lost. Put it back on the pump. I don't know if it helped, but it didn't hurt and I'll always have a spare.
