how do know it`s not your aftermarket gage that`s incorrect. I like how the conclusion was made that the TST info is wrong without proper verification. I`m not trying to be a smart arse either. I just feel that your statement is unfounded without proper verification. You have compared one to another and have no way of knowing without a qualifier.
Dr. Diesel,
I'm not spreading unfounded information here. Most people recommend that gauges should be the very first mod that is done. I chose not to listen to that, and purchased a TST CR R49 w/gauges. One thing led to another, and pretty soon I had 5" straight pipe exhaust, AFE Stage II intake, an II SPS66 turbo, EDGE EZ chip stacked, and so on... and still no gauges. Definately not a smart thing. The TST has the option of setting a maximum desired EGT and Boost... when these values are reached, TST will "backdown" the fuel, to avoid exceeding these values.
The OEM "boost" sensor on our trucks only reads to 39 psi... the same as the upper setting of the TST backdown boost feature. Therefore, when actual boost pressure goes higher than 39 psi, neither TST nor the OEM sensor knows how high because the value is outside the limits of the sensor. Using the stock turbo charger, I don't think that this would be much of a problem. However, larger turbos and stacked fueling boxes all lend theirselves to much higher achievable boost levels... as in my case.
I thought my SPS66 came wastegated to 55 psi, and so even though I knew I would be exceeding the OEM sensor's range, I felt reasonably confident that boost shouldn't exceed this 55 psi level; however, I never hooked a regulated compressed air source to test this as I should have done.
Upon installing analog gauges, I realized immediately why people recommend gauges as one of first mods... my boost gauge pegged 60 psi briefly before coming down, and stabilizing at about 55!!!
No, I haven't verified this using multiple gauges, but I have no reason to doubt that an overfueled SPS66 can make 60 psi boost. If you call Industrial Injection, I believe you'll find the turbo is capable of making 70+ psi boost.
Do a little research around here, ride in a few modded trucks, and I believe you'll find that I'm not just making up good stories with no verification. And, no, I'm not bashing TST... it uses the MAP sensor for its boost reading, and because of that, it can not read above 39 psi boost. It's nobody's fault, it's just the way it is... and analog gauges will prove it.
Hope this helps, Eric
