my trucks thermostat needle is bouncing from approx 160-195 degrees. not constant but at freeway cruising will not stay at 190 degrees then would move and couple of minutes later would move back. . I recently changed the thermostat it was a 190 degree stat. I know that temp has dropped outside and much colder now and does take some time to warm up. but winter shouldnt matter I guess just expose a bad thermostat. so is it possible this 5 month old thermostat just went bad. . or if the needle was acting irratic what could I do to troubleshoot the gauge/needle... any help will be helpful.....
2002 HO 6-SPD LB 4X4 QC HTT 62/14 SB-FE SMARTY TST PM3 MACH 4'S, RINGED AND STUDS, AFE/2
"SILVERLINE D/PRICOL PYRO,BOOST,FUEL FASS 150, VULCAN 1/2 DRAW-STRAW, VULCAN 3/8 FUEL LINE AND FITTINGS, DSS 03 TRAC-BAR DSS BOX TURN-OVER BALL, RIDE RITE AIR BAGS. SUPPORT 17'' KMC BLACK HOSS, 315/70/17 MICKTHOM BMTZ'S 6" RCD LONG ARM LIFT AND DE-BADGED FOR FUEL MILEAGE. :-laf
