fuel comes from the tank to the lift pump, to the filter, to the two
stage high pressure pump( first stage approx 200 psi to second stage 5000 psi at idle up to almost 26000 at full throttle full load,
to common rail, to ecm(computer) controlled injectors that operate
at up to 90 volts. the system uses numerous inputs to determine
injector pulse with and timing, crank sensor, cam sensor, apps,
fuel rail pressure sensor, inlet air temp/pressure sensor, intake air
temp/pressure sensor, coolant sensor. 70% of fuel supplied to the
injectors, returns to the tank for cooling purposes. there is a fuel control actuator, mounted on the high pressure pump( cp3) that
controls the amount of fuel to the high pressure side of the pump,
which = amount of pressure to rail.
the ecm used is manufactured by motorola and operates at 40 mhz, this is the fastest computer chrysler currently uses.
hope this helps, if you want more detail etc, let me know?
James
