What is considered normal oil pressure ?
Speedometer Erratic or Possessed!
Power upgrades-93
I went thru my OEM service manual and can't find the Oil pressure specs. Any one know what they are ? I am running at an idle around 40 psi and 70-80 psi on the highway.
Also what are good "boost" pressures on a stock engine. I am running 26lbs of boost unloaded,floored and about 6lbs at 70mph with stock timing settings.
Kyle
1985 DODGE 1 ton Crew Cab(imported from California with no rust) W/8' box converted to 4X4 in 1999. Converted to a non-intercooled 1991 Cummins Turbo diesel & rebuilt 5 speed Getrag in 2001(wife can't drive a stick :). Freshly rebuilt and Balanced Cummins, Rebuilt NP205, Rebuilt Injector pump and tweaked, Matched Injectors, 3" New Mandrel Bent Exhaust,no muffler, Borgeson Steering Shaft, K&N Air Filter, 4:10 gears, limited slip rear end, 16" Goodyear GSA Wranglers, 16K Reese 5th Wheel Hitch,and LE Package and a Sony CD Stereo. Next add-on some “Banks” toys ! If you want to know why I did all of this, 2 kids, one on the way and I can't stand F**d and Ch**y. Kyle Hoover ,Fruitport, MI.
Kyle, I wouldn't consider your truck stock!
Lets see,
1) tweaked pump
2) matched injectors
3) K&N air filter
4) Straight exhaust
26 # boost is getting up there. Mine is running 27# and it took a rebuilt tweaked pump, PW injectors along with some other stuff to get there. Stock my truck ran at 15# on a good day.
The oil pressures you have looks good. Normal oil pressure for a 91 is 30-70 # @2500 RPM.
filter bypass opens at 65 psi
Oil pressure switch set to turn on light at 12 psi.
Hope this helps
Stan
93 2WD extended cab, Banks Power Pack, K&N air filter, PW Injectors,rebuilt and tweaked pump, auto w/4. 10 rear with limited slip, US Gear Exhaust Brake, 3-1/2" Exhaust, 5K air bags, Boost/Pyro/Tach Gauges, Green/Silver, new 40-20-40 bucket seats, 151K
[This message has been edited by paccool (edited 03-02-2001). ]
Hey Kyle,
According to my manual you're right on the money (30 to 70). Good rule of thumb from all the old time racers was 10 psi per 1000 rpm.
Happy motoring, Jones
Jones
'84 Ramcharger w/CTD, non-gated 12, torqflite, NP205, Dana 60 and 70 w/ 3. 07s. Looks more or less stock.
According to the Cummins Power Masters with warm oil you should have the following oil pressures when taken from the main oil rifle. At Idle 20-30 PSI At 1600 RPM (torque peak) you should have 40-50 PSI At 2000 RPM (cruising speed) you should have 40-55 PSI and at rated RPM (varies by year) you should have 40-55 PSI. Very accurate gauges may show fluctuations of 2-3 PSI with oil pump pulsations. This info comes directly from a letter I received from Cummins in Oct. 2000. Hope this helps. John
1989, 4x4,250, 5spd. Banks Intercooler and Exhaust, Corsair fan clutch, Kelderman air ride (Front & Rear), No-spin rear diff. Gear Vendors and all possible mods. to void warrantee
