mac tools also offers one, i have bought one and have only used it once. it does work well if you have a engine that has the degree marks on the balancer or the flywheel. I personally am a fan of dial indicator or spill port timing methods. This tool is good for checking timing and troubleshooting but does nothing really to help setting the timing, if you are going to use it for that then you are playing a game of trial and error til you get it right. It would work ok on engines that have slots in the mounting surface of the pump or on external pump drive coupling as found on certain engines (isuzu,hino,etc... ) Hope this helps, also on our engines if you have your balancer degree marked, remember that it will always have to be re installed in exactly the same position as it was taken off of the crankshaft. Ours will go on in any position
