What is Normal Operating Temps for the Aisan Auto 6sp transmission?
end of an era for me
dead battery mystry
I installed my CTS insight, no other power enhancements, I saw 148 for a trans temp on the highway yesterday. . What are the normal operating temps? Also if the transmission ever overheats (at which temp, i have no idea!) does the truck go into limp mode or anything to help cool the fluid? I pull a 4,500lb boat and i cant imagine ill ever overheat but im just curious!
Operating temp will always depend on load. Never get above 240° ! I think fluid service intervals are 28,000 miles.
Operating temp will depend on ambient temp. If it is like th erest of the transmissions Dodge uses, no reason to think otherwise yet, 140-240 is the normal operating range. At 260 it will likely start taking over if they have programmed that into the controller. Typically, probably 150-180 is what you will see year round.
Good deal. I havent hooked my boat up yet since the CTS I just want to make sure im in the normal operating range. thanks guys!
Rooster, I tow a lot with my Aisin equipped 3500. On the hottest days, with really heavy loads, if you keep your speed at "normal" levels the temps should stay below 200. Today I hauled a 26,000lb trailer out to a rig location east of Denver. Air temps were in the mid 90s, terrain was flat with rolling hills. Nothing to really slow me down. transmission temps were usually in the low to mid 190s. In the past with much lighter loads on colder days hauling up a steep dirt road, traveling at less than 10mph I could quickly see temps well over 200. If you keep the air flowing over the transmission cooler the temps stay down.
On one of those slow steep hauls I did get the transmission hot enough to get a warning buzzer and idiot light. I don't remember at what temp that happened but the truck didn't go into any kind of limp mode. I just pulled to the top of the hill (it wasn't far) and let the truck relax a bit heading down the other side. It cooled pretty quickly.
I cant imagine you will have any problems. My empty flat bed weighs double what your boat weighs weighs!
