Where is the sending unit? Pan or the hot line? If in the pan, you might not be able make it move, unless towing. Should have a guage that starts at 100*. I had to do the same thing.
I see 130-140* (hot-line) empty. 160-180* (t/c clutch locked). Have seen over 200* when backing a loaded trailer in high range on t-case, or off-road in soft dirt. Going low side drops it back to a good temp.
