hey guys,
I just put a set of Traction Bars on this weekend. I got them used off a friend, but they are LSfarm bars. what is the correct way to preload the bars? Shorter and pull on the rear axle, or longer and push on the rear axle? I got them on and locked the brackets down and then tightened the bars up by hand (sorta like you would an oil filter). I tightened the lock nuts and took her for a ride. Before my truck would jerk your head off when it changed gears and now the shifts are much smoother, there is no engine bounce at each gear change either. I was expecting the truck to be harsher than it already was when it shifted. Just wondering what you guys think.
Thanks, Dave.
Thanks, Dave.
